Author Topic: Manifold Pressure / Boost Sensor  (Read 1328 times)
Offline tommygti
  • -Given: 22
« on: July 13, 2015, 03:36:05 pm »
Ive just run a full vagcom scan on my car as its due for MOT tomorrow. Theres a few codes showing up but one im particularly concerned about is the boost pressure. Heres the code its throwing up:
1 Fault Found:
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 001 - Signal too High
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 166425 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:58:30
             Freeze Frame:
                    RPM: 808 /min
                    Load: 16.9 %
                    Speed: 0.0 km/h
                    Temperature: 75.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 14.097 V
Ive read on a few forums that it can be an issue with the N75 valve and my car has done 103000miles. I also have the forge dv fitted which ive heard can through issues up. Any advice would be appreciated.
