Author Topic: Should mfd show if bonnet is open  (Read 1605 times)
Offline Mill750
« on: July 13, 2015, 08:44:24 pm »
If the mfd shows the bonnet is open as per boot , if it's not highlighted could that mean the sensor has gone . Had a low oil Amber warning today , topped up and the warning did not go out , is this another sign of bonnet sensor gone? Could this sensor be connected to the headlamps too as I have a bulb out light  , all bulbs are fine
Offline doylebros
Re: Should mfd show if bonnet is open
« Reply #1 on: July 13, 2015, 09:32:35 pm »
In key postion 2 - Open the bonnet and then put your wipers on if they work the bonnet switch if most likely defective!
« Last Edit: July 13, 2015, 10:09:10 pm by doylebros »
Offline Mill750
« Reply #2 on: July 13, 2015, 09:43:01 pm »
In key postion 2 - Open the bonnet and then put your wipers on if they don't work the bonnet switch if most likely defective!
Thanks wil try that
Offline doylebros
« Reply #3 on: July 13, 2015, 10:10:22 pm »
My post should of read:-
Offline Mill750
« Reply #4 on: July 18, 2015, 06:00:21 pm »
Bonnet catch replaced !!! Problem solved , thanks for the bonnet up wipers on test  :happy2:
Offline doylebros
« Reply #5 on: July 18, 2015, 06:19:30 pm »
Happy to help
