Author Topic: 7P6 035 730 K Module help  (Read 1073 times)
Offline rubbernut
« on: July 14, 2015, 09:26:03 pm »
Hi i don't know if anyone can help me, i  got my 7P6 035 730 K module with plug and play wiring harness today, i have fitted tonight on my mk6 2010 (60) gtd, I have a rdc310 in at the moment, but there is nothing showing on the radio or MFD is that because of the rcd310 or does it should like there is a problem, I know it needs coding but i expected some signs of life
Many thanks Matt
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: 7P6 035 730 K Module help
« Reply #1 on: July 21, 2015, 01:10:23 pm »
Sounds like your module is dead or your loom is faulty... Can you contact someone like Eddie-NL to check them?
If you can reach them on VCDS to code, it means the module isn't dead, at least.
