Author Topic: P3 Cars Boost Gauge  (Read 5229 times)
Offline chrisr763
  • -Receive: 62
P3 Cars Boost Gauge
« on: July 14, 2015, 09:38:52 pm »
Anyone on the forum running a P3 cars boost gauge? What do you make of it? I've watched numerous videos and they look brilliant. I'm in the process of setting up a group buy (if it passes the admin's approval) if anyone is interested, post your interest on that thread.
MK5 Golf
MK6 Golf
Blurb from their website:
Plug and Play install
Quick plug and play install with zero cutting required. All power, ground, and data points come directly from the diagnostics port connector.
Boost/Vacuum Display
High resolution boost/vacuum via diag port for FAST install. Optionally read boost via boost tap (not included).
Multiple Gauge Displays
Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
Peak Recall & Run Record
Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
Universal Aux Inputs
Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
On the Fly Configuration Menu
Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
Offline STV4R
Re: P3 Cars Boost Gauge
« Reply #1 on: July 14, 2015, 09:46:45 pm »
I have one, it's ok but would be alot better if it had a few more features like the polar fis
Offline Orc
  • -Receive: 25
« Reply #2 on: July 14, 2015, 09:57:01 pm »
Ill be in
Offline howie1987
  • -Given: 92
  • -Receive: 20
« Reply #3 on: July 14, 2015, 11:31:00 pm »
I have one. I like it but its a bit pricey for what it is in my opinion but everyones different.
Offline arris
« Reply #4 on: July 15, 2015, 08:44:57 am »
I really fancy one of these but the price really puts me off, in reality it's really expensive for what it is...
Interested to know the group buy price tho...
Offline neiller
  • -Given: 32
« Reply #5 on: July 15, 2015, 09:52:16 pm »
What sort of price would it be ? I like the look of those
Sent from my SM-N9005 using Tapatalk
Offline Madone
  • -Receive: 27
« Reply #6 on: July 15, 2015, 09:57:00 pm »
I looked at this but went with the polar FIS instead, does loads more and integrates much better by seamlessly integrating onto the canbus, hence nothing to plug into the obd. The FIS literally has every engine perameter available. Plus it can change settings in the ecu in the same way VagCom does to enable things like video in motion and dipping passenger mirror when you select reverse. Worth a look.
Offline chrisr763
  • -Receive: 62
« Reply #7 on: July 22, 2015, 02:46:29 pm »
Ill be in
Good to hear! I will keep you posted @Orc
Will be around £300 + Postage I imagine.
I agree, but the Gauges look so clean and OEM. It's defiantly somthing for people to consider  :happy2:
Offline LondonGT
« Reply #8 on: July 25, 2015, 04:59:49 pm »
Do you need vagcom to install it? I'm keen on the P3 but it is pricey, waiting to see on group buy price.
The FIS does look good too but I quite like the idea of a separate gauge.
Offline chrisr763
  • -Receive: 62
« Reply #9 on: August 05, 2015, 07:02:37 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,99603.0.html
I imported a few gauges from the US to see how they sell and nobody is interested...
I'm assuming its the price putting everyone off? Not sure a group buy is viable with 0 interests  :ashamed:
Offline GTi-Andy
« Reply #10 on: August 05, 2015, 07:19:12 pm »
I'd be in Chris, obviously price dependent!
So much for keeping it standard!
Offline LondonGT
« Reply #11 on: August 05, 2015, 07:37:38 pm »
Is that £300 in a vent? It was $489 in a vent pod, so around the same but I guess you're saving the postage and import duty?
Offline chrisr763
  • -Receive: 62
« Reply #12 on: August 05, 2015, 09:15:05 pm »
Okay Andy - Il see what I can do!  :happy2:
Yeah - Literally top of the range - Red/Red. In vent with optional analogue boost tap. I can also add in the performance chip which gives a few additional features.  :happy2:
Offline LondonGT
« Reply #13 on: August 06, 2015, 02:13:06 pm »
What does the extra chip do?
Offline chrisr763
  • -Receive: 62
« Reply #14 on: August 06, 2015, 02:17:20 pm »
On top of 0-60 times
60-130
130-0
0-130 (I think)
60-0
I can't actually remember, il have to write them down next time I'm next to it!
