Author Topic: 7P6 035 730 K Bt module help  (Read 2862 times)
Offline rubbernut
« on: July 15, 2015, 06:04:06 am »
Hi i don't know if anyone can help me, i  got my 7P6 035 730 K module with plug and play wiring harness today, i have fitted last night on my mk6 2010 (60) gtd, I have a rdc310 in at the moment, but there is nothing showing on the radio or MFD is that because of the rcd310 or does it should like there is a problem, I know it needs coding but i expected some signs of life
Many thanks Matt
« Last Edit: July 15, 2015, 07:37:17 am by rubbernut »
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: 7P6 035 730 K Bt module help
« Reply #1 on: July 15, 2015, 12:12:51 pm »
Think you need 7P6 Rev M for the mk6.
I tried Rev J in mine and had the same issues, in the end I swapped it for 5K0035730B, which works :)
Offline rubbernut
« Reply #2 on: July 15, 2015, 12:15:02 pm »
Thanks for your reply the guy on eBay said it would be fine, so it's not just a coding thing
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: July 15, 2015, 03:44:34 pm »
module is either faulty or the loom
contact the seller
Cluster and Key coding
Location Great Yarmouth
Offline rubbernut
« Reply #4 on: July 15, 2015, 04:00:04 pm »
contact the seller
So i should have some use Eddie-nl
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: July 15, 2015, 04:18:29 pm »
module is either not being powered up or is faulty.
as i don't know where you bought it or the type of loom used i can't narrow down what the issue is
Offline rubbernut
« Reply #6 on: July 15, 2015, 04:35:16 pm »
If I can get my money back do you sell them Eddie-nl
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: July 15, 2015, 04:37:26 pm »
see if the module is getting power
Offline rubbernut
« Reply #8 on: July 15, 2015, 05:06:43 pm »
I will unplug it again tonight and see, the radio is getting power though the plug play harness
Offline rubbernut
« Reply #9 on: July 15, 2015, 06:35:44 pm »
Ok Eddie-nl just been out to the car read somewhere about aux, put it on and SEAT_bt came on paired it and it works, but nothing on the MFD so i gather that's a coding job? Also was able to answer the call on the MFSW
Thanks again for you help Eddie-nl
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: July 15, 2015, 09:15:52 pm »
it won't display on a red highline, unless you have a polar fis add on
Phone button only works with mk6 wheel
Offline rubbernut
« Reply #11 on: July 15, 2015, 09:18:44 pm »
It's a mk6 2010 (60) plate GTD so I have white highline, so think it will work?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: July 15, 2015, 09:49:55 pm »
sorry should have paid more attention.
Yes it should display and steering wheel phone button will work
If not then get address 77 added to the gateway installation list
