Author Topic: RS3 TTRS BRAKE CALIPERS  (Read 2345 times)
Offline jack2012
« on: July 16, 2015, 08:48:31 pm »
hi all what discs are you using on the rs calipers as the audi ttrs 370mm genuine discs have warped  :confused:and in need off advice  :happy2:
« Last Edit: July 16, 2015, 09:18:37 pm by jack2012 »
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: RS3 TTRS BRAKE CALIPERS
« Reply #1 on: July 17, 2015, 06:28:15 pm »
The latest solution is to use the 340mm TTS disc. Much lighter than the 345mm R32 disc. I'd imagine you'd need a different carrier/adapter coming from 370s.
If you need the size, there's a two piece 362mm option, but it's a bit dear.
There are quite a few good threads on the subject, and Dave B and Alex at AKS seem to be the guys with the knowledge.
dansmith180
« Reply #2 on: July 17, 2015, 08:30:56 pm »
340mm TTS discs with fitting kit from AKS by DaveB is the way to go, I've spanked mine with no issues. Also its cheaper to by the discs and brackets than to buy just new TTRS discs.
Offline mvb12
  • -Receive: 64
« Reply #3 on: July 17, 2015, 10:22:13 pm »
out of interest, what pads you use and what style of driving?
Offline jack2012
« Reply #4 on: July 19, 2015, 09:38:56 am »
i been using padgid rs pads
Offline jack2012
« Reply #5 on: July 19, 2015, 09:44:29 am »
what about using the Mercedes ml disc with the rs brakes?????
Offline dan930
  • -Receive: 56
« Reply #6 on: July 19, 2015, 10:55:35 am »
Im using pagid blue pads(think they are the RS pads)
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline mvb12
  • -Receive: 64
« Reply #7 on: July 20, 2015, 12:20:29 pm »
you do track days? if yes, how many with the TRS discs?
Offline jack2012
« Reply #8 on: July 22, 2015, 11:48:58 am »
i have done 2 track days with the ttrs disc and they are crap now having to buy a new pair or go to the ml disc set up
