Author Topic: S3 alloy intercooler install....anything to prepare for? Which bolts?  (Read 2388 times)
Offline 18Edition30
As above guys, going to tackle this at the weekend on the edition 30.
Anything to bear in mind in particular?
I read somewhere that you need different/longer bolts/screws to go into the alloy cooler, is this right? Or will my gti bolts/screws work?
Any good how to manuals about?
« Last Edit: July 29, 2015, 08:04:19 pm by 18Edition30 »
Re: S3 alloy intercooler install....anything to prepare for?
« Reply #1 on: July 21, 2015, 09:42:23 pm »
It will look like this
« Reply #2 on: July 21, 2015, 09:44:28 pm »
Just watch the a/c pipes don't get stressed like mine did in the photo on my gttdi
Offline v4rley
  • -Receive: 104
« Reply #3 on: July 22, 2015, 04:17:47 am »
I'm also going to be tackling this next week hopefully. You need different bolts for the cooler as the current one uses bigger threads for the current plastic cooler. Through reaserch people suggest M6 x 16mm bolts (I got some stainless from eBay 10 for £2)
Guide:
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/28-ENGINE-Intercooler_Replacement/28-ENGINE-Intercooler_Replacement.htm
Not sure what you hose situation is but I'm re-using my standard GTI good info about how to do it best here:
http://forums.vwvortex.com/showthread.php?5158183-S3-Intercooler-Installed-and-Logged!&p=69487956&viewfull=1
« Last Edit: August 05, 2015, 06:49:26 pm by v4rley »
Offline 18Edition30
« Reply #4 on: July 29, 2015, 05:28:48 pm »
Can someone confirm which bolts I will need to buy to go in the alloy cooler?
Wanting to buy so I can get it fitted over weekend.
Thanks!
Offline v4rley
  • -Receive: 104
« Reply #5 on: August 08, 2015, 08:28:01 pm »
Thanks!
Did you get yours fitted @18Edition30 ?
Offline 18Edition30
« Reply #6 on: August 10, 2015, 02:03:53 pm »
Thanks!
I did bud yes, can confirm it was m6 x 16mm bolts needed!
All went smoothly and seems to have sharpened the car back up again!
Offline v4rley
  • -Receive: 104
Re: S3 alloy intercooler install....anything to prepare for? Which bolts?
« Reply #7 on: August 10, 2015, 03:23:16 pm »
Cool just did mine on sunday and a definite improvement! Much better ait temp and more secure fixing on the alloy tank ends  :drinking:
« Last Edit: August 10, 2015, 05:42:20 pm by v4rley »
Offline 18Edition30
« Reply #8 on: August 10, 2015, 08:38:44 pm »
