Author Topic: MEGA- Mk6 Candy White GTi, Stage 3 K04, Brembos, BBS, Coilovers  (Read 49314 times)
Re: Got a Golf eventually... Mk6 Candy White GTi
« Reply #60 on: August 22, 2015, 07:39:48 pm »
Should sent the Ko4 off to TTE haha 0:-)
Offline Gaz
« Reply #61 on: August 22, 2015, 07:52:21 pm »
Thanks chaps. With the CKs im hoping im totally happy with the look of it. Might need to adjust the coilovers to suit but will see.
I dont think theres much point spending all that money to upgrade the K04, if it makes 360bhp+ which they can i will be happy, theyre quick cars at that power and i will be happy there. :)
Offline doylebros
« Reply #62 on: August 22, 2015, 08:06:53 pm »
Enjoyed reading your thread and noticed you've done the tensioner mod but If your engine code is the CCZB I would be looking at changing this 27 item
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1735&ein=2010&f=649&hauptgr=1234567890&hg=1
This is a bit extra info
http://www.autoserviceprofessional.com/article/93400/noisy-audi-chain
It's becoming a common problem and an expensive repair when it fails. However, a  simple enough job if caught early but a real chew if the gauze breaks free giving G40 fault code and a nasty knocking at 2000rpm.
Offline mdmay
  • -Given: 38
« Reply #63 on: August 22, 2015, 09:22:16 pm »
I have suffered the indignity of this failure and the bill attached to it
Regards,
Mike
Offline doylebros
« Reply #64 on: August 22, 2015, 09:33:06 pm »
I have suffered the indignity of this failure and the bill attached to Ithaca
The cheap or expensive one?
Offline Gaz
« Reply #65 on: August 22, 2015, 09:35:07 pm »
My car is about 1 year newer than the effected engines but i'll make sure i double check to be sure. As per tensioner, id rather spend £100 now than risk £1000+ later!
Michael, so youve been bitten by both? Sure you said you had a failed tensioner too!?
Offline mdmay
  • -Given: 38
« Reply #66 on: August 22, 2015, 09:36:59 pm »
I had luckily just the failed tensioner. But was a whole new engine
Regards,
Mike
Offline doylebros
« Reply #67 on: August 22, 2015, 09:44:03 pm »
If you still have a rattle after the tensioner job has been done when cold get the bridge bearing replaced or you'll end up with a new cylinder head and cams!
Offline Gaz
« Reply #68 on: August 22, 2015, 09:49:36 pm »
I never had a rattle before, i just changed it as a precaution.
Thanks anyway.
Offline Gaz
« Reply #69 on: August 24, 2015, 08:47:08 pm »
Today i got the K04 compressor housing back with the new outlet welded to a great standard thanks to Scott at Magma Fabrications! He also made me a wee blank plate for the PCV outlet i wont use on the compressor housing.
Built it back up so its ready to fit.
Heres a before and after, mod required to fit K04 to TSI !
Offline mdmay
  • -Given: 38
« Reply #70 on: August 24, 2015, 09:04:20 pm »
Hope I was able to help mate
Regards,
Mike
Offline Gaz
« Reply #71 on: August 24, 2015, 09:40:07 pm »
Your info has been handy mate, i wish you had more pics of your turbo though! Would have gave me an easier job! ;)
Fingers crossed what ive done fits nicely!
Offline Gaz
« Reply #72 on: August 25, 2015, 08:39:22 pm »
Eventually got a set !!
19x8" BBS CK ET44 with 225/35R19 tyres. Only done 500miles too!
Swapped the Falkens for my Eagle F1s and got them straight on!
Looks totally different, take a bit getting used to silver instead of dark!
Offline mdmay
  • -Given: 38
« Reply #73 on: August 25, 2015, 08:40:19 pm »
Looking great
Regards,
Mike
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #74 on: August 25, 2015, 10:05:59 pm »
Firm 'Yes' from here Gaz  :happy2:
Works well  :party:...
Pete
