Author Topic: Battery help needed  (Read 908 times)
Offline yin
  • -Given: 77
Battery help needed
« on: July 23, 2015, 07:14:59 pm »
Just collected a new battery for 2007 Cupra have eurocarparts given me the correct one if not which one should i have
Thanks  :smiley:
Offline th3_f15t
  • -Receive: 183
Re: Battery help needed
« Reply #1 on: July 24, 2015, 06:01:17 pm »
Pretty sure that isn't the right one! Looks too small and will move about in the housing which isn't safe. Although, check the power ratings, output ect. and if its the same then you could try using foam padding to secure it in the battery case.
Offline david25
  • -Given: 19
« Reply #2 on: July 25, 2015, 06:55:17 pm »
I have a "shorter" battery installed if the new one has B13 clamp down (I think) the metal bracket will fit into the V marks on the bottom.
