Author Topic: R32 rear brake conversion  (Read 21087 times)
Re: R32 rear brake conversion
« Reply #30 on: December 23, 2008, 07:39:39 pm »
Hi
im new around here but i have a set or R32 rears that im hoping to fit to my mk v over the next few days . I can post back here with my findings if it helps .
Liam
Hi Liam. welcome to the forum.  :smiley:
It would be great if you could do that, and if possible a bit of a write up and pics.  :drinking:
Offline tony_danza
  • -Receive: 112
« Reply #31 on: December 24, 2008, 08:46:41 am »
Good man Liam!  :happy2:
Sideways yo!
Offline liamo
  • 2.0 16v TDI
« Reply #32 on: December 24, 2008, 05:55:09 pm »
[/quote]
[/quote]
Thanks for the welcome
Ill put together some pic and a write up if it all goes to plan with the fitting
Offline tony_danza
  • -Receive: 112
« Reply #33 on: December 24, 2008, 09:17:12 pm »
Autotech have told me today that they even utilise the splash guards and it is pretty much bolt on... I guess we'll see?
Sideways yo!
Offline liamo
  • 2.0 16v TDI
« Reply #34 on: December 25, 2008, 07:18:03 pm »
I have the splash gaurds for  these aswell . I should have some answers by tomorrow evening .
Offline liamo
  • 2.0 16v TDI
« Reply #35 on: December 26, 2008, 05:10:35 pm »
Ive had a look at fitting these this morning on my own car  ( 2004 2.0 TDI )
I did a dry run (brake pipe not plumbed ) and it all bolts up fine bar the lower of the 3 screws for holding on the splash gaurd . I drilled a new hole for this and spaced it  out with a m8 nut with a slightly longer bolt . Ill be fitting the for proper in the next week and ill get better pics then if anybody wants them .
« Last Edit: December 26, 2008, 08:26:05 pm by liamo »
Offline cmdrfire
    • Commander Fire - my blog
« Reply #36 on: December 26, 2008, 05:51:41 pm »
It's good to hear that it's a goer!
« Reply #37 on: December 28, 2008, 12:19:45 am »
thats great, wish i bought the rears now when i paid for the fronts!
« Reply #38 on: January 03, 2009, 01:26:00 pm »
Do the S3 brakes fit the GTI and and are they a straight swap like the R32 fronts.  :smiley:
Offline tony_danza
  • -Receive: 112
« Reply #39 on: January 03, 2009, 03:24:13 pm »
They're exactly the same, save for a little cover with "S3" on it.. I think you can buy the cover and stick it on the R32/Leon brakes - if you wanted to?
Sideways yo!
Offline gazbutS3
« Reply #40 on: January 03, 2009, 06:10:23 pm »
There are some on Ebay at the minute
http://www.mk5golfgti.co.uk/forum/index.php?topic=1150.0
Offline cmdrfire
« Reply #41 on: January 05, 2009, 12:57:19 pm »
This dude got R32 fronts and rears on his Rabbit of Superior Breeding:
http://www.golfmkv.com/forums/showthread.php?t=72561
Offline davo01
« Reply #42 on: January 10, 2009, 10:51:03 pm »
both fit front and rears fit straight on.you do need r32 hoses for the front as there different to other golfs.the set up is 345 vents front and is it not 332 vented rear?
« Reply #43 on: January 11, 2009, 10:49:31 pm »
its vented at the rear too
« Reply #44 on: January 23, 2009, 07:43:35 pm »
Hi
Liam
Liamo how is your conversion going is it done yet.  :jumping:
