Author Topic: A few VCDS codes  (Read 7718 times)
Offline Jayy26
A few VCDS codes
« on: July 24, 2015, 10:44:26 pm »
 :surprised: a few codes my mate has just pulled up hopefully someone can help and one of these is the main problem to my rad fans not working?
Car has got a decat *cough* revo said they had took this of with the map but obviously not
The relay labeled 1 is getting warm so that might help
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2735184
   Coding: 0403000318070060
   Shop #: WSC 00015 210 70345
   VCID: 63CFA3C6A21A403913D-8036
8 Faults Found:
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 153007 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:03:34
             Freeze Frame:
                    RPM: 1530 /min
                    Load: 26.7 %
                    Speed: 41.0 km/h
                    Temperature: 85.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
001670 - ECM Power Relay Control Circuit
               P0686 - 002 - Short to GND - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 153319 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:09:09
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 72.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 1.524 V
001672 - ECM Power Relay Load Circuit
               P0688 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 153319 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:09:09
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 72.0°C
                    Temperature: 38.0°C
                    Voltage: 0.381 V
009730 - Coolant Pump Control Circuit
               P2602 - 002 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 153319 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:42:36
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 41.0°C
                    Voltage: 0.000 V
000257 - Mass Air Flow Sensor (G70)
               P0101 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 153321 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:32:05
             Freeze Frame:
                    RPM: 1524 /min
                    Load: 22.0 %
                    Speed: 0.0 km/h
                    Temperature: 81.0°C
                    Temperature: 35.0°C
                    Voltage: 14.224 V
012403 - Fuel Pump Circuit
               P3073 - 004 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 153357 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:13:00
             Freeze Frame:
                    RPM: 872 /min
                    Load: 18.4 %
                    Speed: 0.0 km/h
                    Temperature: 110.0°C
                    Temperature: 49.0°C
                    Voltage: 13.716 V
012599 - Intake Manifold Runner Control
               P3137 - 001 - Basic Setting not Completed - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 140 /min
                    Load: 71.3 %
                    Speed: 0.0 km/h
                    Temperature: 57.0°C
                    Temperature: 49.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 8.636 V
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 140 /min
                    Load: 71.3 %
                    Speed: 0.0 km/h
                    Temperature: 57.0°C
                    Temperature: 49.0°C
                    Voltage: 7.239 V
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 19C802087F2D8405485AC69010CC
   Shop #: WSC 00139 210 82586
   VCID: 78F5E4AA0B9CB3E156F-802D
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
any help would be great cheers
« Last Edit: July 24, 2015, 10:51:47 pm by Jayy26 »
Offline Jayy26
Re: A few VCDS codes
« Reply #1 on: July 26, 2015, 11:24:13 pm »
bump
Offline Jayy26
« Reply #2 on: July 28, 2015, 02:47:56 pm »
anyone?
Liam0205
« Reply #3 on: July 28, 2015, 09:50:10 pm »
Might not be much help but have you looked the codes up on the Ross Tech website for a few reasons as to what the issue could be?
Offline Jayy26
« Reply #4 on: July 30, 2015, 01:21:39 pm »
Cheers bud ive had a quick glance but i think its going to take me a while to troubleshoot ;/
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #5 on: July 30, 2015, 10:18:54 pm »
P0420 is the rear O2 sensor...just had that code and replacing the rear O2 fixed it. The rest you can sort out here: http://wiki.ross-tech.com/wiki/index.php/Main_Page
Enter the codes into "Search"
Offline Alex157_gti
  • VCDS 2015 Edition
  • My Ride: Focus ST
« Reply #6 on: July 31, 2015, 01:59:09 am »
The alarm horn will be either the siren in the drivers side front arch as battieres corrode or the switch on your drivers side door pillar easy fix for your diy
Let me know if you want any help with this
2005 Gti Black 18" monzas, full leather, sunroof, sat nav, heated seats. highline, high spec
Sheffield.
VCDS 2015 Edition Hex+Can Can help out
Offline Jayy26
« Reply #7 on: July 31, 2015, 04:05:32 pm »
yeh its because i have a decat,have you heard of them blank pieces of metal that apparently bypass this?
so does the alarm use a different battery?which switch bud?
Offline Alex157_gti
  • VCDS 2015 Edition
  • My Ride: Focus ST
« Reply #8 on: July 31, 2015, 05:44:23 pm »
alarm.
The siren has built batteries so the alarm works if you ever get a flat battery but they are known To corrode over time and cause the alarm to fault and either not working or make the alarm go off.
Its in the drivers front wing in a metal box bolted to the chasiss
Also the switch it next to the drivers seat on the b pillar it turns the sensors off if you ever wanna leave dogs in the car or sensors for towing
Alex
Sheffield.
Offline Jayy26
« Reply #9 on: August 01, 2015, 04:28:02 pm »
Any help on these would be great i dont even know where to start...thanks
Possible Causes
   Power Supply Relay for Engine Control Module (J271) faulty
   Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271) faulty
Possible Solutions
   Check/Replace Power Supply Relay for Engine Control Module (J271)
   Check Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271)
   Check/Replace Engine Control Module (J220)
Possible Symptoms
   Engine Coolant Fan running at full Speed while Ignition is OFF and Engine is COLD (could lead to discharged Battery)
Possible Causes
   Fuse(s) faulty
   Terminal 87 faulty/hanging
Possible Solutions
               P2602 - 002 - Short to Ground – Intermittent
Cannot find this in ross tech but it seems to come with the faults above ^^
               P0101 - 008 - Implausible Signal – Intermittent
Possible Symptoms
   Loss of Power
   Erratic Idle
Possible Causes
   Mass Air Flow Sensor (G70) faulty
   Air Leak(s) after Mass Air Flow Sensor (G70)
   Excessive restrictions in the Intake/Exhaust System
   Dirty air filter, clogged snow screen, clogged CAT
   Ground Spots corroded or Paint Residue
   Wiring and/or Connections from/to Mass Air Flow Sensor (G70) faulty
Possible Solutions
   Check Intake Air Filter
   Check Mass Air Flow Sensor (G70)
   Check Ground Spots
   Check Wiring and/or Connections from/to Mass Air Flow Sensor (G70)
               P3073 - 004 - Electrical Malfunction – Intermittent
Possible Symptoms
   Malfunction Indicator Light (MIL) ON
   No start or performance problem(s)
Possible Causes
   Wiring and/or Connector(s) from/to Transfer Fuel Pump (G6) -or- Fuel Pump (FP) Control Module (J538) faulty.
   Transfer Fuel Pump (G6) faulty. See Special Notes
   Fuel Pump (FP) Control Module (J538) faulty.
Possible Solutions
   Check Fuse(s), Wiring and/or Connector(s).
   Check/Replace Transfer Fuel Pump (G6). See Special Notes
   Check/Replace Fuel Pump (FP) Control Module (J538).
Special Notes
   When found in the M.Y. 2006 - 2007 NAR BPY 2.0T FSI engine see:
   TSB 01-08-06 -or- TPI 2017131 which mentions "updated" electric/transfer (in tank) fuel pumps.
               P3137 - 001 - Basic Setting not Completed – Intermittent
Possible Causes
   Intake Manifold Runner Control Basic Setting not performed
Possible Solutions
   Perform Intake Manifold Runner Control Basic Setting
Special Notes
   When found in Engine: 2.0l TFSI
   Perform Basic Setting.
   Check TPL 2016420 (RoW)
   Check Engine Control Module Software Version, if necessary perform Update.
   Replace Intake Manifold Runner (V157) with updated part.
Possible Causes
Control Module and/or Sensor Power Supply faulty
Possible Solutions
Check Control Module and/or Sensor Power Supply
Special Notes
Check Wiring from/to the following Components and Components themselves:
Manifold Pressure / Boost Sensor (G31)
Intake Manifold Tuning Valve Position Sensor (G336)
Low Pressure Fuel Sensor (G410)
Check TSB 01-08-12 or 2018402
Additional information may be found by searching RVU 24M2 / O3 (Exp. date November 30, 2011) or calling the VW dealer and checking the VIN.
Just found the last fault on this page and looks like it could just be down to that?
Offline Jayy26
« Reply #10 on: August 02, 2015, 07:33:16 pm »
anyone ever changed there ECU ?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11 on: August 04, 2015, 06:02:15 pm »
You mean the O2 spacer? Yes, it helps a majority of those whom have tried it. I think it is best to replace or you can clean, only cleaning is said to only last a short time and why I think replacing is best. I just got the code again and need to replace the second O2 now.
On your multiple codes...remember to address the first codes to pop up. Look at the timeline for the codes, address the first to pop up because one code can lead to others. Fix one, clear the codes, and address further should other codes appear again continuing to address by timeline that they appear.
« Last Edit: August 04, 2015, 06:06:30 pm by ROH ECHT »
Offline Jayy26
« Reply #12 on: August 06, 2015, 01:29:22 am »
thats the one haha well i have a decat so cleaning wouldnt help would it?
right got you..well apparently my mates dads said it the control main relay? :/
