Author Topic: Kenwood dnx 520 map update?  (Read 5373 times)
Offline hlcst
« on: July 26, 2015, 07:52:22 pm »
Hi I've just recently fitted a dnx520vbt and need to update the map but I'm not sure where to buy it from has anyone used this place before?
http://www.navmapstore.com/category/101/Kenwood_Update
I don't know why but garmins website just says not available online so any help much appreciated.
Offline LondonGT
« Reply #1 on: July 27, 2015, 10:03:50 pm »
Direct from kenwood!
Always cheapest
However they update the maps late in the year so expect the 2015 in the autumn
Offline hlcst
Re: Kenwood dnx 520 map update?
« Reply #2 on: July 27, 2015, 10:23:37 pm »
Cheers for that I'll hold out a little longer now
Offline TForrest94
« Reply #3 on: July 30, 2015, 02:16:32 pm »
I did my 521 last year the update was free it only costs if you wanna dd speed cameras  or more regions if I can remember correctly
Its just a way of life.
Offline hlcst
« Reply #4 on: July 30, 2015, 07:37:31 pm »
Where do you get the free update from bud?
Offline TForrest94
« Reply #5 on: July 31, 2015, 01:17:27 am »
Can't remember specifics but give this a go
https://kenwood.garmin.com/kenwood/
Offline hlcst
« Reply #6 on: August 01, 2015, 05:55:58 pm »
Thanks for all the advise so far I've got the map update but now I've discovered I need to update the garmin firmware and also the kenwood firmware to 1.4 which has thrown a spanner in the works.
I can sort the garmin update as it's just done with an sd card but I don't have a cd/DVDs writer on my netbook so does anyone know if you can update the kenwood firmware via usb?
Offline TForrest94
« Reply #7 on: August 02, 2015, 10:10:48 pm »
I'm pretty sure it all has to be done by USB, all updates on my head unit I've read to use us. Instead of sd card
Offline hlcst
« Reply #8 on: August 03, 2015, 10:47:03 am »
After reading the precautions part on this http://www.kenwood.com/cs/ce/mm/firmware/2010/2010c/pdf/10NAV_MM_R_FWverup_en.pdf
Usb seems to be a no go but I was hopeful some else has used a usb successfully.
It looks like I'm off to buy an external cd writer
Offline TForrest94
« Reply #9 on: August 03, 2015, 12:04:33 pm »
If that's what they say then use a cd, I haven't done any firmware updates but always stick with what they say
Offline xjay1337
  • -Receive: 377
« Reply #10 on: August 03, 2015, 12:11:08 pm »
Did you get the latest map updates FOC? would you possibly be able to show me where you got them
Offline hlcst
« Reply #11 on: August 04, 2015, 10:06:06 am »
xjay1337
I think I have got the maps mate but I wont know for sure if its working until I update my unit. If it is the updated maps and all is working well I will send you the files if you want because they are a nightmare to get hold of.
Offline xjay1337
  • -Receive: 377
« Reply #12 on: August 04, 2015, 12:13:09 pm »
Yeah if it works you'd be a super star.
