Author Topic: RNS-315 and MSFW not working  (Read 4089 times)
Offline Vr6will
« on: July 29, 2015, 09:36:32 pm »
Hi everyone,
I've recently purchased an Edition30 for my fiancĂ©e.  It is 56 plate with DSG and the previous owner had the RNS-315 Sat Nav / BT / DAB fitted.  The only thing that was really missing was the MFSW, so bought the buttons and installed them.  I have coded the steering wheel in VAGCOM so it knows the buttons exist and the buttons on the right hand side of the steering are working and controlling the MFD+ as expected, but the buttons on the left hand side of the steering wheel are not working.  I've looked under the Navigation in VAGCOM but nothing obvious to make it recognise it.
Any ideas as to what I'm missing?
Offline Vr6will
Re: RNS-315 and MSFW not working
« Reply #1 on: October 01, 2015, 02:33:45 pm »
Still struggling with this, been doing some more research and appears to be down to the RNS315 unit only taking BAP but my MFD+ only talks DDP
I'm not too fussed about the full cluster integration (nav, etc) but i'd really like to get the buttons to work so volume and answering phone
I'm guessing this requires a cluster change?
« Last Edit: October 01, 2015, 02:36:23 pm by Vr6will »
Offline Pashka
« Reply #2 on: October 01, 2015, 08:37:06 pm »
what's ur can gateway part number?
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Vr6will
« Reply #3 on: October 03, 2015, 06:41:26 pm »
Hi @Pashka, just did a quick scan on vag com:
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 100213F1000579
   Coding: 350003
   Shop #: WSC 12345 123 12345
   VCID: 74E1EA1DD738249E49-8020
No fault code found.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Offline Vr6will
« Reply #5 on: October 08, 2015, 10:04:16 am »
Hummmm,
I have read that it might be possible if using the mk6 steering wheel controller (CH I think it is) - would that mean using mk6 buttons too?
http://forums.vwvortex.com/showthread.php?5597802-4-Spoke-MFSW-to-3-Spoke-Mk6-MFSW-with-DSG-Paddles-DIY
Quote
Update: FYI It is said (or "Some say..." for my Top Gear fans) that if you purchase and install an RNS-315 on a car with a RED MFA and an MK5 (or old style) MFSW, that you will lose steering wheel audio controls (volume, etc.). They also say you will lose the ability to display Audio, Bluetooth and Nav info in the MFA. I can confirm you lose info displayed in MFA. However, when I installed my RNS-315 (which I purchased WELL after I did this swap), I was excited when I realized my steering controls worked perfectly as regards the radio. I am assuming that is because the MK6 style steering wheels use the new communication method. So when I swap out my cluster for the New R-Line cluster with color MFA the remaining button (menu left) on the SW will work and I will have full radio MFD display.
