Author Topic: Loose metalic noise over bumps (From under the car - Front OS)  (Read 3052 times)
Offline jayha11
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97064.0.html
I drive over what feels like a 100 speed bumps each day. Whilst driving home last night I had the windows open and the radio off. I quickly noticed when driving over the speed bumps I can hear a clunking metallic noise which appears to be coming from the front OS under the car. I had a butchers underneath when I got home but couldn't see anything out of the ordinary. Will jack it up at the weekend for a better inspection. Was hoping someone may have experienced this before and point me in the right direction?
Mk5 GTI > S3 8P > Cupra 300 > Cupra 290 > Mk5 R32
Offline tlnds
Re: Loose metalic noise over bumps (From under the car - Front OS)
« Reply #1 on: July 31, 2015, 09:01:43 am »
There's many things on the suspension setup to check but I noticed a slight rattle from N/S rear last week which gradually got worse, had a look underneath but couldn't see anything loose and turned out a spring had given in. Common problem on mk5's so worth checking.
Offline PhilNUK
  • -Given: 32
« Reply #2 on: August 02, 2015, 06:24:45 pm »
I been getting a clunking sound and had it checked out and its the steering rack.  Steering feels fine, I just get clunking over bumps..
Was worst case scenario with it being so bloody expensive to replace too.
Offline jayha11
« Reply #3 on: September 11, 2015, 09:12:59 pm »
So I figured out where the noise was coming from in the end. Turns out the OS rear brake shield's bolts had rusted/sheared off. I opted just to remove it instead of stripping everything down to re-fit a new part. No more rattles! Hurrah!!
