Author Topic: mk6 aircon controls  (Read 8844 times)
Offline Newbieintown
Re: mk6 aircon controls
« Reply #15 on: December 30, 2015, 02:47:27 pm »
Hi is there a way of telling if I have 1 or 2 flap motor?
200bhp
Tornado Red
2006
Offline downtime
« Reply #16 on: December 31, 2015, 04:11:55 pm »
If your car is before mid 2006 then 99% you have two motors, if after that then most likely only one. I've seen instructions somewhere how you can make both motors work in parallel by modifying the connections behind the climatronic panel.
« Reply #17 on: December 31, 2015, 06:13:05 pm »
It's a 56 plate, hope it has the 1 flap fingers crossed.
200bhp
Tornado Red
2006
Offline LondonGT
mk6 aircon controls
« Reply #18 on: January 25, 2016, 11:18:40 pm »
Marko how did you get on?
And I have an '08 mk5 so is it really as simple as a pin swap?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #19 on: January 26, 2016, 12:20:42 am »
Yes.
Offline LondonGT
« Reply #20 on: January 26, 2016, 07:27:30 pm »
Ok to clarify:
Mk5 'manual' controls can be swapped for mk6 'manual' controls and will work if you swap a couple of pins in the back?
I'm not talking about automatic duel aircon
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #21 on: January 26, 2016, 07:44:38 pm »
Ok to clarify:
Nope. mk5 manual are levers, mk6 manual are electric buttons. You'd still need to replace it all.
Offline Pashka
« Reply #22 on: January 26, 2016, 08:42:53 pm »
Ok to clarify:
to add mk6 climatic controls to mk6 you need to add 1 small servo motor for the flap which is not hard to do. It was done on b6 passat and everything works fine.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #23 on: January 26, 2016, 08:52:09 pm »
Ok to clarify:
Is there a DIY link for that retrofit? I know a couple of guys who'd like to do it... :happy2:
Offline mk5Eire
« Reply #24 on: January 29, 2016, 10:22:37 pm »
Have a look over on vortex there was defo a thread somewhere on it AFAIK .
Sent from my iPhone that holds battery for 48 minutes
