Author Topic: Faults urgent help  (Read 618 times)
Offline Washout
Faults urgent help
« on: August 02, 2015, 03:14:25 pm »
Hey chaps urgent help help needed. Installed new gateway and radio now have many faults after scanning with vcds, are these real faults what should I do clear them etc. please help
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=c9cqi6shksmkjpi7h08h24plvo&/topic,19740.0.html
Re: Faults urgent help
« Reply #1 on: August 02, 2015, 03:32:11 pm »
Did you reconfigure the gateway with all your installation options?
Offline Washout
« Reply #2 on: August 02, 2015, 03:42:53 pm »
The gateway was pre coded for me matey. Is it usual to get faults after installing a new can?
« Reply #3 on: August 02, 2015, 04:31:14 pm »
Just clear the faults as removing/installing the gateway throws up tons of them.
If there's an issue(s) it/they should be reflagged on another scan.
« Reply #4 on: August 02, 2015, 05:08:08 pm »
As per bacillus post. If its been coded correctly then once all codes have been cleared that should be fine.
Offline Washout
« Reply #5 on: August 02, 2015, 06:04:07 pm »
Cool thanks for the help guys I will clear the codes tomorrow is it best to go through each module individually to clear the codes or can I just clear all. Cheers
« Reply #6 on: August 02, 2015, 06:14:12 pm »
Just use the clear all DTC function, that should do it.
Offline Washout
« Reply #7 on: August 02, 2015, 06:56:38 pm »
Cheers rich really appreciate the help.
