Author Topic: Headlights problem  (Read 1734 times)
Offline Remon_uk
Headlights problem
« on: August 02, 2015, 08:17:34 pm »
Hi all,
I have a problem with my headlights, over the last two three years my headlights have started getting worse, not sure if it's mist or cracks or a chemical or what. Has anyone else had this problem? VW Hvae advised to replace them both, obviously lol. I want a cheaper option Atif anyone knows a quick fix ?
Thanks guys
Re: Headlights problem
« Reply #1 on: August 02, 2015, 08:28:57 pm »
You can buy head light restorer at halfords and it works a treat
Offline Washout
« Reply #2 on: August 02, 2015, 09:21:28 pm »
This one on ebay is the one that people have had good results with. Remember it removes the protective uv coating so you will need to put a seal/protectant on them.
http://m.ebay.co.uk/itm/251749289972
Offline white91
« Reply #3 on: August 02, 2015, 09:24:25 pm »
Get a machine polisher
Offline SRC
  • -Receive: 27
« Reply #4 on: August 02, 2015, 10:14:43 pm »
I can't tell from the pictures - is it external or internal?
External - use one of the headlight restorers, which involve polishing the surface.
Internal - you've most likely got a faulty seal, probably around the bulb holder.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline Skylinegtr
« Reply #5 on: August 03, 2015, 10:35:09 am »
A good buff will bring them out like new :happy2:
Offline percy
« Reply #6 on: August 03, 2015, 12:16:32 pm »
3m do a good headlight restoration kit around £20 mark, also guides on YouTube showing how to do it and it works great . If you do you use one of these kits then make sure you cover the engine bay with a cloth as the residue that splatters up is a pain to get off.
Offline Remon_uk
« Reply #7 on: August 06, 2015, 08:47:09 am »
Thanks guys for your help, I brought Meguires restoration kit from eBay, worked well... :congrats:
Offline GTIEagles
« Reply #8 on: August 06, 2015, 09:28:16 am »
Another tip, make sure you put plenty of tape round the bumper because when I did mine the disc kept slipping off and consquently cut into the paint work of the bumper a few times  :congrats: Personally if I was to do mine again I would remove them and do them on a bench, that way you can get right to the edges without fear of damaging your paint work.
Offline xjay1337
  • -Receive: 377
« Reply #9 on: August 06, 2015, 11:05:53 am »
Quite common on a lot of cars...
We tape them up. Generally start at 1000 grit and work up to 3000 then compound and polish.
