Author Topic: Mk6 heater control issue help  (Read 10909 times)
Offline Ma22789
« on: August 04, 2015, 01:30:02 pm »
So I have fitted this mk6 heater control to my mk5 and all seems to be working fine until I press the AC button and it shuts of all the vents and also every time I start the car up it seems to rest the controls and there turned all the way up to the hottest temperature.. If anyone could help it would be much appreciated thanks
  gti ed30 2007 stage 2+ ths loba bcs itg
Offline v4rley
  • -Receive: 104
Re: Mk6 heater control issue help
« Reply #1 on: August 04, 2015, 02:19:19 pm »
You do realise they are MK7 controls?? :scared:
Offline Ma22789
« Reply #2 on: August 04, 2015, 02:50:34 pm »
Came out of a mk6 convertible
Offline Matto
  • -Receive: 116
« Reply #3 on: August 04, 2015, 04:07:52 pm »
Definitely looks like the MK7 panel. This is the MK6:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #4 on: August 04, 2015, 07:21:40 pm »
It's the MY2013 climatronic, not compatible with our mk5. I asked my friend who knows these stuff well about it. Sorry @Ma22789, no luck there...
Offline Ma22789
« Reply #5 on: August 05, 2015, 08:34:05 am »
Well it works so there must be a fix or a few wires needing to be switched maybe..
There must be somebody who knows I really don't want to take it out  :sad1:
Offline doylebros
« Reply #6 on: August 05, 2015, 06:17:16 pm »
This member fitted that panel into MKVI - he done plenty research so he may know why it's not suitable for a MKV - for me it's as previously stated I've not noticed it in a MKV :wink:
http://www.mk5golfgti.co.uk/forum/index.php/topic,79815.0.html
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #7 on: August 05, 2015, 06:42:17 pm »
AFAIK all mk6 are compatible with the new AC panel, just the mk5s aren't.
Offline mo
« Reply #8 on: August 07, 2015, 04:23:37 pm »
I have heard in that the late MK6 Convertible panels are supposed to work
http://www.mk5golfgti.co.uk/forum/index.php/topic,79815.15.html
The Passat B6 panels also work and have the same wiring as the MK6 panels a lot of the guys have fitted to their mk5's.
The MK7 panel looks the same as the late MK6 convertible but will not work.
@Ma22789 Whats your part number ? According to the following thread the pn you need is 3AD 907 044 G (Passat B6)
http://vw-golfclub.ru/forum/showthread.php?t=42611 (russian site so run through Bing Translator)
According to this Vortex thread some extra pins may need connecting
http://forums.vwvortex.com/showthread.php?4938269-OEM-MKVI-Climatronic-on-a-MKV-on-a-RNS-510-Screen-installed
Pay attention to where it quotes the following:
Climatronic Wiring
On A Connector (black) extract both; Pin 16 and Pin 20 and put Pin 16 on the place were Pin 20 was, leave the wire on Pin 20 loose (not connected to the harrnes) for later connect the Air Quality Sensor if needed.
If you have an older VW Model you will MIGHT need this wiring change ATTENTION: Please don´t quote me on this, I just really followed some threads on VWNAVI that mention this change. It did not applied in my case)
Motors in parallel:
On C Connector (brown): Pin 7 connected to Pin 10 and Pin 8 connected to Pin 9
On B Connector (black): Pin 6 to Pin 7
« Last Edit: August 07, 2015, 04:59:44 pm by mo »
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9 on: August 07, 2015, 07:36:09 pm »
Not having a direct fit frame puts me off this retrofit as well. I like things to look tidy. With some customization it's possible to fit it and later paint the frame and centre vents to look good, I know. Too much work in my opinion, so I forgot about it. :indifferent:
Offline mo
« Reply #10 on: August 07, 2015, 09:10:27 pm »
Same here. Though i will probably attempt it should some cheap parts appear on ebay or a ready made frame becomes availible which im sure will do eventually.
« Last Edit: August 07, 2015, 09:11:59 pm by mo »
RNS510 & MDI
Offline waj27
« Reply #11 on: August 20, 2015, 12:50:29 pm »
Great help
Offline Ma22789
« Reply #12 on: August 20, 2015, 05:47:49 pm »
Climatronic Wiring
Motors in parallel:
That's my part number it came from a 2013 maybe 14 convertible golf r I tried the pin swap from connector A but still no good and sorry for the late reply I have been away
Offline Pashka
« Reply #13 on: August 20, 2015, 05:54:14 pm »
I have seen mk7 climatronic in b6 07-08 passat so it should be possible
To do that.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline mvb12
  • -Receive: 64
« Reply #14 on: August 26, 2015, 09:14:24 am »
@Eddie-NL can you shed some light on this at all?  :popcornsoda:
