Author Topic: Edition30 preventive maintenance  (Read 4445 times)
Offline Rado16v
« on: August 04, 2015, 06:51:07 pm »
I have a 07 Edition 30, manual with 48k miles and thinking of some preventative maintenance after reading all the horror stories here. Does the following sound correct and still relevant? All my searhes bring back old threads.
DV revision G
PCV revision R ?? seen the wrong ones cause problems
Cam follower
Thanks in advance.
Offline allymac
Re: Edition30 preventive maintenance
« Reply #1 on: August 04, 2015, 06:55:57 pm »
Yep you could do the belt and water pump if not done yet, I also did the pick up pipe in my sump. Probably few other bits I can't think of at the minute.
Offline hlcst
« Reply #2 on: August 04, 2015, 06:57:58 pm »
I would imagine your cam follower is still in good shape with only 48k as mine done 90k but it's a nice and easy diy for peace of mind and have a look at the part number on the bottom of your pcv to go like for like
Offline skard
  • -Receive: 245
« Reply #3 on: August 04, 2015, 07:22:03 pm »
The main thermostat on the ED30 is becoming quite a common part needing replaced
Offline Matthewsarg
« Reply #4 on: August 04, 2015, 08:38:29 pm »
And you could get your inlet valves walnut blasted to clear all the carbon deposit
Offline Rado16v
« Reply #5 on: August 05, 2015, 08:50:46 pm »
Thank you chaps.
Inlet valves looks a bit full on but the other jobs look straight forward, a local specialist has quoted £120 parts £50 labour for pcv, dv and cam follower. Seem reasonable? I'll try and get thermostat thrown into that.
Offline flashp
  • -Receive: 65
« Reply #6 on: August 05, 2015, 09:16:51 pm »
Thank you chaps.
If your other parts aren't faulty then inlet valves should be right at the top of the list. Do them before you replace something that isn't broken.  :happy2:
Mine at 40k'ish miles:
« Last Edit: August 05, 2015, 09:19:48 pm by flashp »
Gone but not forgotten :-)
Offline Rado16v
« Reply #7 on: August 05, 2015, 09:51:08 pm »
Thank you chaps.
That's unbelievable the build up on those. Wish I never opened my gob now!
Offline flashp
  • -Receive: 65
« Reply #8 on: August 05, 2015, 11:06:28 pm »
It doesn't look good does it!
It's why the new engines now have injectors to wash a little fuel/mixture over the valves to keep them clean.
Here's my original post covering this: http://www.mk5golfgti.co.uk/forum/index.php/topic,79369.msg825776.html#msg825776
I included a bulletin from VW in there which is worth a read.
Offline Rado16v
« Reply #9 on: August 07, 2015, 08:14:21 am »
Thanks for that link, was very informative.
My wife uses the car mainly to and fro work so car sees mostly short journeys and never really thrashed, which will do it some good.
Are there any vw specialists who offer the walnut blasting service? I've seen now on a few bmw/mini forums, specialists who offer the service I may try one of them.
Offline david25
  • -Given: 19
Offline flashp
  • -Receive: 65
« Reply #11 on: August 08, 2015, 11:11:49 am »
Short journeys don't help these engines and can be considered arduous conditions. Cylinder temps need to get higher than that which might be normal for some to assist in keeping things clean. In these engines anything above 3k rpm for 15mins+` brings about a marked increase in combustion chamber temperature (&EGT's) and a sort of cleaning cycle. It won't get rid of everything but it helps.
I drive 5.5 miles to work and by the time I get there my engine oil is only just at the same temp as the coolant. Because of this and the fact that I do 2/3 track days a year I do two oil changes a year. Ironically not thrashing may be working against you here, especially if the same driving habits persist after cleaning.
I believe that there are number of other factors affecting this and these are: extended service intervals, engine oils which could be better (consider an Ester based synthetic of the specified grade http://chemlube-malaysia.blogspot.co.uk/2012/11/the-benefit-of-ester-based-synthetic-oil.html), cheaper fuel that doesn't assist in cleaning or burn as cleanly (V Power Nitro scores well here) and an engine not being properly used. My personal coice of oil is this: http://www.opieoils.co.uk/p-1146-silkolene-pro-s-5w-40-ester-synthetic-oil-for-high-performance-engines.aspx
All of this simply an opinion based on what I've researched and learnt through talking to my specialist.
Catch tanks may or may not assist in this matter, the jury is out on this one. I have one but I wouldn't say it's a silver bullet, but with other measures taken it may contribute to keeping things cleaner for longer. Where these fit in the intake system isn't the only  engine breathing path that contributes to getting things mucky. Having an engine on boost changes things in this respect. A vehicle driven with low boost/revs may benefit from one more than one that spends more time on high boost, especially during the winter months.
It was explained to me that these engines also have overlapping cam timing which can assist in 'baking in place' these deposits.
Addressing these points won't miraculously transform it into a spotlessly clean engine but I believe it will help as some engines with similar mileages can be very different from one another for no apparent reason other than owner/driver imposed variables.
My specialist once told me that he sees some engines which are very much cleaner than others at similar mileages. Given modern manufacturing techniques and quality control the biggest variable in a cars life is the owner/driver.
« Last Edit: August 10, 2015, 03:38:42 pm by flashp »
