Author Topic: r-tech pcv delete or catch can???  (Read 10819 times)
Offline Stooey
« on: August 04, 2015, 06:53:36 pm »
I'm looking either fit a catch can on do a pcv delete but I'm unsure which is better? What are the pros and cons for each? I'm guessing the r-tech delete will be better as they know there stuff but just after finding out a bit more if anybody has any info.
Offline th3_f15t
  • -Receive: 183
Re: r-tech pcv delete or catch can???
« Reply #1 on: August 04, 2015, 09:25:18 pm »
I've seen a lot of mixed views on this. A catch can is probably my choice, as deletes can cause excess pressure inside the engine. plus a catch can filters some stuff from passing through the engine.
Thing is you need to get a well designed catch can to make it worth while, think the Draft 42 Designs one was mentioned as a good one in the apst but don't quote me.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: August 04, 2015, 09:31:18 pm »
The catch cans are no better than the deletes, all (aside from the R-Tech setup) reduce the breathing capacity of the engine (both cam and crank) down to a 19mm hole (or less), which does cause excessive pressure and leads to smoking on overrun/idle.
The R-Tech kit runs a separate large bore breather for the cam and crank gases. No back pressure, no hot oil vapors making their way back in to the turbo intake etc.
Get the R-Tech kit - Cheaper than a decent catch can setup and does a better job
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: August 04, 2015, 09:37:33 pm »
I may consider that myself actually, thanks for that.
Offline Stooey
« Reply #4 on: August 04, 2015, 09:40:33 pm »
Thanks for the reply lads, think the r-tech delete is the way to go then  :drinking:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=84uues9602pl684lgg80cji1b1&/topic,19740.0.html
« Reply #5 on: April 02, 2019, 05:13:54 pm »
Looks like R-tech have stopped selling this now  :confused:
Offline v4rley
  • -Receive: 104
« Reply #6 on: April 02, 2019, 05:45:43 pm »
Yes they have, but apparently AKS have started to make / develop this own now  :confused:
« Reply #7 on: April 02, 2019, 06:01:14 pm »
Wonder why they stopped making them?
I've just opted to replace the front and rear PCV with new OEM ones. The rear PCV is original so on 128k miles.  :scared:
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #8 on: April 03, 2019, 08:52:29 am »
Because PCV deletes causes issues with crankcase pressure and burning oil/smoke. Mine was OK at first but started with age/time. I'm now back on the factory PCV and will be keeping it that way
« Reply #9 on: April 03, 2019, 09:28:35 am »
Thought so. Thanks dan.
« Reply #10 on: April 03, 2019, 02:07:31 pm »
Went to pick the stuff up today and the rear pcv doesn’t have s valve in it. Just a flexi metal hose and short rubber hose that attaches to the cam cover. Is that right?
Thought it had a valve in it.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #11 on: April 03, 2019, 08:59:21 pm »
As long as you don't have a P revision front PCV, then it doesn't need a checkvalve. I'm currently using an N and the latest is R - both are fine without a checkvalve in the rear pipe
« Reply #12 on: April 04, 2019, 11:20:38 am »
Lovely. Thanks agains. I’ll replace the pipe anyway as I am stripping it.
