Author Topic: Spec & Fitting RNS510  (Read 984 times)
Offline da_ansa
« on: August 06, 2015, 10:12:45 am »
Hi all,
First of all I have used the search function but haven't come across what I am looking for.
I am looking at purchasing a RNS 510 and i've seen a Version P that seems to be reasonably priced. Does anyone know the spec or specific differences between this version and others?
In terms of fitting it will be going into a 2007 golf so im aware i would need a canbus gateway but also coding, is this correct?
Thanks in advance!
Offline da_ansa
Re: Spec & Fitting RNS510
« Reply #1 on: August 14, 2015, 02:19:49 pm »
bump
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: August 14, 2015, 03:25:39 pm »
Version P is LED, A B and C come in LCD.
Mostly just hardware changed but same functionality as any other RNS (Unless its a DAB)
You need the GPS Antenna, aeriel antenna adapter and yes canbus and coding.
