Author Topic: idle judder & poor cold starts  (Read 9870 times)
Offline Martk19871
  • Va Va Voom
Re: idle judder & poor cold starts
« Reply #15 on: August 17, 2015, 06:26:46 pm »
Not really sure,  but stuggling when cold and get some movement In the needle then settles. VW are keeping it in tonight and going to get in touch tomorrow, got a courtesy UP for now
Offline Bo!
« Reply #16 on: September 05, 2015, 09:11:43 am »
Update .
Car has been in to dealers for a couple days there conclusion is that the car is running as lean as possible and that is the reason for the car misfiring. And that the engines map is able to adapt and correct the misfires. I was told they had a job to find the misfires and when they did it misfired 2 times in an hour on one cylinder and 1 on another.
So the vcds scan I had must have been to sensitive.?
Really not sure what to do now they said on the phone they are not willing to investigate further . And will not accept me rejection of the vehicle as they have said there is nothing wrong .
Offline Tiggymala
  • Golf MKV GTI
« Reply #17 on: September 05, 2015, 12:08:16 pm »
Do you get any rough idle after you have given it a bit of a spirited drive after u sit in idle any idle drops? As others have said carbon build up whip off intake manifold clean out intakes and injectors as you said it has 50k on it probably why it was traded into a dealer before will defo need doing if it has never been done with that mileage
Offline Bo!
« Reply #18 on: September 05, 2015, 09:17:02 pm »
When you say idle drops Tiggymala do you mean the Rev counter dropping .? Or just the feeling of the idles dropping off .?
Offline Bo!
« Reply #19 on: October 25, 2015, 04:52:48 pm »
So after several visits back to the dealer PCV spark plugs and coil pack replaced there's no improvement  . The dealer and customer services have concluded there's nothing they can do . The dealer have said there are misfires occurring but as there is no EML there happy there's nothing to worry about.i have spoken to VW tuners and have been advised the only real way of diagnosis is by removing the injectors and flow testing them and a de Coke if required .
Offline Gmaster
« Reply #20 on: October 27, 2015, 10:06:00 pm »
Highly recommend Volkscraft in Exeter independent Vag specialist .
I've been using them for years really know their stuff .
They are based in a Marsh Barton so not to far away from you.
I'm in Wellington .
Offline Bo!
« Reply #21 on: January 01, 2016, 05:38:06 pm »
Well after numerous visits back to the dealers and with their assurance that my issues are not a failing or clogged injector, more normal characteristics of an engine of my age.
I booked the car in for media blasting going in on Monday & I am hopeful this will finally solve the issues I'm experiencing .
Offline Bo!
« Reply #22 on: January 05, 2016, 11:39:23 am »
Went in for the walnut blast yesterday took the car in 9Am and it was ready to collect 5pm cost was £270 all in, also got before and after video of the valves they were quite bad but are gleaming now . Idle has smoothed out but it is very early on to call it a success only drove 70 miles on the way home.
Offline gokgti
« Reply #23 on: January 05, 2016, 06:35:43 pm »
Just take it to a proper specialist or someone that knows TFSi's well and give VW UK the bill they dont give a toss if its something past a coil pack, jokers.
Offline chris s
« Reply #24 on: January 31, 2016, 07:35:28 am »
Would u mind you mind sharing where you took it for the walnut blast?
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline Madone
  • -Receive: 27
« Reply #25 on: January 31, 2016, 08:58:15 am »
Hope this fixes it for you, in relation to your findings on VCDS etc, the ECU has tolerance before it records a actual fault, for example you can get misfires and it won't class it as a fault, there needs to be a level of misfire before it even logs it as an issue. If the second tech you took it to just looked at the blocks he could well have seen a miss, but if its below the threshold it won't log as a issue. Hence the first dealer would look for ECU error codes and there would be non. I have heard many TFSI cars have very slight miss on idle, its subtle, but common
Offline Bo!
« Reply #26 on: January 31, 2016, 06:25:03 pm »
The techs both advised it was missing (misfiring) but as it was not on a specific cylinder it was not a fuel injector issue . VW technical had copy's off the measuring values recorded on a dis file & advised that it was normal characteristics for my engine, the reason i was getting a misfire was these cars run so lean on idle unburnt fuel causes a misfire . Since having the walnut blasting the cold starts have been much better. However  I do still feel a miss every now and then when stationary at idle when at lights etc . If this isn't normal the only possibility left I believe is injector(s).the video of the shell blasting before and after was proof enough that it needed doing the back of the valves were stinking so I'm glad I had it done anyway.
Offline Craig Stanley
« Reply #27 on: June 12, 2016, 08:49:06 pm »
Can you share where you got this done please.
Sent from my SM-N910F using Tapatalk
