November 26, 2024, 05:28:24 am
All Things Mk5
Mk5 General Area
Hi guys my traction controll button does not want to switch off
Topic: Hi guys my traction controll button does not want to switch off (Read 577 times)
danielsh
August 07, 2015, 09:21:58 am »
Hi guys my traction controll button does not want to switch off..any ideas?
da_ansa
Always Involved
-Given: 8
-Receive: 0
Re: Hi guys my traction controll button does not want to switch off
Reply #1 on:
August 07, 2015, 04:53:41 pm »
Are you pressing and holding down the button?
AJP
Global Moderator
Just look at my post count
-Given: 392
-Receive: 316
Reply #2 on:
August 07, 2015, 07:38:15 pm »
This could be a faulty abs pump. It's well documented. Do a google. And good luck.
doylebros
-Given: 44
-Receive: 309
Reply #3 on:
August 07, 2015, 07:46:04 pm »
If as the above suggest you've got the common fault of G201
To make progress on this type of issue its best to have the vehicle scanned with a VCDS tool any of these near you:-
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
Then if the fault shows that code plenty dealers have corrected this issue FOC.
This is worth a read
http://www.r32oc.com/topic/47215-fault-code-01435-g201-help-literature-needed/
Last Edit: August 07, 2015, 08:02:36 pm by doylebros
fletch-
Taking part
-Given: 1
-Receive: 2
Reply #4 on:
August 07, 2015, 07:50:00 pm »
When I hold my traction button, it flashes rather than illuminates? It does turn it off though, is this right? 58 plate tdi
RetroRaz
-Given: 32
-Receive: 194
Reply #5 on:
August 09, 2015, 11:06:39 pm »
Best way to check is get it scanned with vcds (vag com)
#RetroRaz -
https://instagram.com/retroraz/
All Things Mk5
Mk5 General Area
