Author Topic: gateway fault or? radio related  (Read 2768 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: gateway fault or? radio related
« Reply #15 on: August 07, 2015, 02:02:56 pm »
The radio not powering with ignition has nothing to do with gateway coding related to the radio. That I know for sure because I had my first RNS-510 running well with Navigation not activated in the gateway installation list for a couple of months. It was corrected later but I didn't notice any difference in the HU work.
For what I understood you only get sporadic errors related with the radio/infotainment, right?
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
« Reply #16 on: August 07, 2015, 02:09:17 pm »
i always get infotainment code and sometimes intermittant radio comms code
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #17 on: August 07, 2015, 02:13:41 pm »
Can you share the exact VCDS error list?
Offline olethalb
  • -Receive: 31
« Reply #18 on: August 07, 2015, 02:50:32 pm »
i wrote them down before battery died on laptop
1305 - infotainment
1300 - nav
1304 - radio
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=tifev3ccgm4g3vo49tl2ai5a2f&/topic,90967.msg917089.html#msg917089
« Reply #19 on: August 07, 2015, 03:27:23 pm »
I'd try another gateway you can have my old one if you want (version f)?
This is what i noted down as checked when i replaced my gateway
00
01
02
03
08
09
15
16
17
19
25
37
42
44
46
52
55
56
05 | Tornado Red | DSG
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #20 on: August 07, 2015, 04:17:29 pm »
I think you might have a bad connection to the gateway somewhere in the loom or connectors, and that is stopping the gateway to communicate properly with the radio, giving the other 2 errors.
That would explain the radio not powering up correctly. The aftermarket radio might not need a good communication with the gateway to power up normally.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #21 on: August 07, 2015, 04:19:33 pm »
Ross-Tech Wiki:
Quote
01304 - Radio: No Signal/Communication
Possible Symptoms
    Reduced Functionality
Possible Causes
    Communication from/to Radio faulty
    Wiring/Connectors from/to Radio faulty
Possible Solutions
    Check Communication from/to Radio
        See Measuring Value Blocks (MVB)
    Check Wiring/Connectors from/to Radio
01304 - Radio: Implausible Signal
Possible Symptoms
Possible Causes
    Radio Coding incorrect
Possible Solutions
    Check Radio Coding
Offline olethalb
  • -Receive: 31
« Reply #22 on: August 17, 2015, 03:17:58 pm »
Ok just read on another forum about 'the fuse mod' to enable fitting later stereos without battery drain but stereo loses memory
I remembered seeing this in the golf and was there when previous owner bought the car (mfd2 fitted)
I've removed the add on and popped the fuse in the slot closest the bonnet so i'll see what happens at 4pm when i leave to go home
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #23 on: August 17, 2015, 04:04:34 pm »
That looks very bodgie  :confused: fingers crossed.
Offline neiller
  • -Given: 32
« Reply #24 on: August 17, 2015, 10:34:27 pm »
Your fuse goes in the other slot ! It's slot 19 as far as I can remember , I was running this mod for a week while waiting on a new canbus gateway
Sent from my SM-N9005 using Tapatalk
Offline olethalb
  • -Receive: 31
« Reply #25 on: August 17, 2015, 11:33:07 pm »
Yep all sorted, fuse is in correct place or stereo doesn't work at all, i think F19 yes :)
