Author Topic: GTI Forge TWINtake air intake - Review....  (Read 246380 times)
Re: GTI Forge TWINtake air intake - Review....
« Reply #375 on: December 15, 2012, 04:19:02 pm »
Forge had the car in 2010 to test the Twintake / TwinCooler on my car. They decided to use a hard pipe with 90 degree bend as opposed to earlier versions using a 90 degree silicone pipe.
....Hmm, perhaps I should upgrade to a hard pipe. I'm surprised that a hard pipe would make any significant difference over the silicone.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #376 on: December 15, 2012, 05:31:18 pm »
The hardpipe is for Leon fitment, and to be honest i would rather have some siliconehose in my turbo than aluminium pieces RR  :wink:  :laugh:
Over the top mod list ;o)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=iuab46gq0cnk3cpb7plkmof0p1&/topic,19740.0.html
« Reply #377 on: December 15, 2012, 05:34:01 pm »
It will make no performance difference.
« Reply #378 on: December 15, 2012, 06:14:46 pm »
....That's what I thought too  :happy2:
....Exactly! Also, the silicone has a tad more tolerance to movement  :happy2:
Offline paulk
« Reply #379 on: December 15, 2012, 07:35:14 pm »
had the forge twin take on my R for a few weeks , cant fault it . Good bhp gains sounds good but not loud , fitted pretty good but i did move the hose clip round so it didnt rud like the one one here
Offline gigolo456
« Reply #380 on: February 25, 2013, 11:50:05 pm »
Hi Folks, sorry to resurrect this thread but does anybody know if it's difficult or not to clean the Twintake filters? In other words, is it a skilled job to screw off the clamps and take the filter housing off, or is there more to it?? Nick @ R Tech kindly did this, and then merely tapped the ground once the filter was off to get rid of the dust, etc, but typical me,  i paid little or no attention!!  :confused:
Many thanks
Andrew
« Reply #381 on: February 26, 2013, 12:22:01 am »
Having seen them up close, it looks like the jubilee clips can be done with a flathead screwdriver and then you pull off the canisters. Each one has screws - just undo one end and take out the filter. I'm sure there's a guide from Forge floating around somewhere.
The question is how do you clean the filter? That's what I like about OEM - just switch the filter panel. Once you get the engine cover off.  :grin:
Offline gigolo456
« Reply #382 on: February 26, 2013, 01:17:25 am »
Cheers. From doing a bit of reading, a light blowing on the filter itself usually suffices, but as I said, Nick at R Tech just tapped it on the ground and sure enough there was quite a bit of dust! On the side one however there was hardly anything, so read into that what you will, lol! My biggest fear I guess is not being able to connect it all up again! :-S
« Reply #383 on: February 26, 2013, 08:35:05 am »
You are supposed to wash the filters in some soapy water, rinse thoroughly with clean water then allow to dry before reinstalling them.   :smiley:
Offline Bryan
« Reply #384 on: February 26, 2013, 06:00:24 pm »
My silicone pipe has been rubbing on a clip underneath an is starting to wear, i have adjusted it a few times but still rubs eventually....think i will swap it out for this hard pipe.
Contact forge directly i supose??
Forge Twintake. BCSautomotive turbo back exhaust with sports cat. Stage 2 remap. R32 rear lights and bumper. Team heko wind deflectors. mtec bulbs. Ed30 bbs wheels.  Eibach springs. Goodyear Eagle F1 asy2s. NQSBBK(330mm)
twainf
« Reply #385 on: March 03, 2013, 03:10:58 pm »
Some serious reading in this thread about the twintake.  Just about to order one myself.
Offline horice
« Reply #386 on: March 17, 2013, 12:39:48 pm »
Great review RedRobin, and thanks for the heads up on the hose clips Chungster!
Offline NeilM
« Reply #387 on: March 23, 2013, 08:34:23 pm »
Just taken my TWINtake of and sold it, found this which was rubbing out of sight somewhere, not right through though.
« Reply #388 on: March 26, 2013, 12:43:39 am »
....So that appears to be against rubber piping on the engine side and is hidden from view by the front mounted filter cannister.
Offline v2brett
« Reply #389 on: March 29, 2013, 10:04:39 pm »
did notice the potential for this rubbing issue when installing my twintake and spent ages trying to adjust it out,  i never had an issue with it but the car was sold a few month later so i guess the above is the outcome.
was still a great bit of kit though  :happy2:
Still Here!
