Author Topic: PCV delete  (Read 7552 times)
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: PCV delete
« Reply #15 on: August 12, 2015, 12:32:46 pm »
Venturi through the exhaust would be best but is costly and will need some custom fab as there is no off the shelf kit in the UK (that i know of).
If you can't have them drawn out, then leaving them to escape with as little restriction as possible is the next best thing. I still believe that 2 x 25mm pipes venting naturally is better than 1 19mm (or less) I.D. opening being drawn out through the TIP (PCV delete with catch can). Most aftermarket PCV deletes have such a small recess for the passing of the crank and cam gases that no amount of syphoning will help
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
Re: PCV delete
« Reply #16 on: August 12, 2015, 12:48:21 pm »
i haven't seen your setup Dan, a year or so ago i had the crank venting 19mm hose under car then had bsh delete using the port that was supposed to connect to crank venting cam cover gasses via 19mm under car.
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline neiller
  • -Given: 32
Re: PCV delete
« Reply #17 on: August 13, 2015, 12:12:52 am »
Will venting to atmosphere pass mot ?
Sent from my SM-N9005 using Tapatalk
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: PCV delete
« Reply #18 on: September 16, 2015, 12:40:56 pm »
Dan, Did you just use longer hoses for the r-tech pcv delete kit or the ones that came with the kit ?
Silver is the way !
Offline Chris92
  • -Given: 33
Re: PCV delete
« Reply #19 on: September 16, 2015, 10:38:25 pm »
Il be looking at this Soon, going to clean intake valve then look at a delete to stop them clogging up again. Where are you guys seeing the r tech one? I can't see it on the site.
Offline olethalb
  • -Receive: 31
Re: PCV delete
« Reply #20 on: September 17, 2015, 09:53:56 am »
it won't stop it, just slows it down
