Author Topic: Cars ride height for dyno use  (Read 3105 times)
Offline PM30S
  • Edition 30 Revo Stage 2+
« on: August 11, 2015, 11:42:15 am »
Just called R Tech to book in for a stage 2+ remap and DSG map.
They said if my car was lowered they could not carry this out, they told me to adjust my coilovers to standard ride height.
I have had prior cars remapped which have been lowered without any problems gaining access on to the rollers.
Could other members with lowered cars explain how low their cars were when they visited them.
Offline kr15h_ED30
Re: Cars ride height for dyno use
« Reply #1 on: August 11, 2015, 12:19:44 pm »
had mine done just with h&r springs, think its ok long as its not stupidly low
Offline PM30S
« Reply #2 on: August 11, 2015, 12:25:11 pm »
I agree my car clears all speed bumps and was fine on the brake test with mot as this is quite a drop.
Very annoying.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #3 on: August 11, 2015, 02:08:35 pm »
There was a similar thread recently, again regarding R Tech's rollers. It looks like anything up to 40/50mm is fine. Maybe they're used to slammed mk4s turning up and struggling!
Kam88
« Reply #4 on: August 11, 2015, 05:19:41 pm »
Mine is eibach 30mm and that was just alright on their ramp when i went there. Might be worth speaking to them as coilovers instantly might put them on alert not every garage can accommodate really low cars
Offline PM30S
« Reply #5 on: August 11, 2015, 05:42:32 pm »
my tyres have a gap between the arch all round.
Just had 4 new pilots and 4 wheel alignment setup. Don't really want to have to have this alignment done again
« Last Edit: August 12, 2015, 12:27:12 am by PM30S »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=oc4ek0omhl34ejno5l66c3lmlc&/topic,19740.0.html
« Reply #6 on: August 11, 2015, 06:56:57 pm »
How low is it.? Measure the arch to floor distance.
« Reply #7 on: August 11, 2015, 07:27:04 pm »
Mine went on okay on thier rollers
Offline Rob.
« Reply #8 on: August 11, 2015, 07:35:19 pm »
They were proper stressing me out when I said I'd bought the car lowered on springs and couldn't change it! But turns out it was actually fine.
Offline PM30S
« Reply #9 on: August 12, 2015, 04:56:23 pm »
Just measured the arch to floor. From the floor to base of arch behind the front wheel is 13 cm and the height to the top of the arch in the centre of the front wheel is 63cm.
Please could others check if there cars are this height.
All the best
« Reply #10 on: August 13, 2015, 12:31:16 am »
63cm will be fine
