Author Topic: Fault code Cat  (Read 992 times)
Offline clemo
Fault code Cat
« on: August 11, 2015, 09:16:43 pm »
Hi,  So ive put a new 3" Sports CAT down pipe on  to stock back  and tonight after a bit of a run  management light came on , i have a maxi scan in the boot so i stopped and checked it said : P0420 Catalyst System Efficiency Below Threshold Bank 1
Any Ideas please
Offline Flyingscotsman
Re: Fault code Cat
« Reply #1 on: August 12, 2015, 11:39:29 am »
The ECU thinks the OEM VW cat is still there and is working below it's efficiency.  Some people find a lambda probe spacer works, but I believe the only sure way to remove light is to get lambda probe mapped out.
Offline clemo
Re: Fault code Cat
« Reply #2 on: August 12, 2015, 12:29:40 pm »
Thanks for the info .... Are we talking the probe up near the turbo or behind the CAT
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
Re: Fault code Cat
« Reply #3 on: August 12, 2015, 12:52:46 pm »
behind cat, or 'post cat' monitors the efficiency / operation of the cat
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline clemo
Re: Fault code Cat
« Reply #4 on: August 14, 2015, 04:09:03 pm »
This fault pops up every day , can i not address the issue with VCDS
Re: Fault code Cat
« Reply #5 on: August 14, 2015, 06:37:52 pm »
You need to get it mapped out or use a spacer as said above.  :smiley:
Offline clemo
Re: Fault code Cat
« Reply #6 on: August 15, 2015, 02:43:51 pm »
OK thanks ill try spacers , after the CAT , now i did another Maxiscan and the volts look good on sensor 1 fluctuating between lean and rich but on 2 its also up and down, does this mean the CAT ive just got is no good ?? How can i check if the CAT is working correctly  i have VCDS
« Last Edit: August 15, 2015, 02:46:49 pm by clemo »
