What did you and your MKV do today?
Started by ROH ECHT, June 12, 2011, 03:07:21 AM
Previous topic - Next topic
ljc19630
Quote from: absolute on August 21, 2019, 08:56:06 PM
Placed it for sale........................
??????[emoji102]
JTI
Quote from: Shoduchi on August 20, 2019, 12:33:26 PM
The mk6 R DSG didn't get the Golf ball-shaped gear knob. Just the mk6 Edition 35. The mk6 R got this one instead:
:smiley:
Nice looking shifter, might have to consider that as a future upgrade.
pudding
Quote from: Stupots on August 18, 2019, 08:01:30 PM
@Pudding it was from VW main dealer. It was £96 which is crazy, but I only expect to do it once. I should have thought about paint or nail varnish on the ends; I may do that.
It was one of the 30 degree days, so was flexible enough, not too bad when you get in a flow.
FFS  :grin:  It's generic trim cut to length!  Oh well, if that's the cost, that's the cost.  Thanks mate  :happy2:
pudding
Bashed my pre-cat out and did some chassis tuning (ARB and damper adjustments) and it feels a tad keener to move and corner now  :smiley:
I bashed the cat out a few years back on my original DP but it made no difference, but this time around it definitely has.  Maybe it's just the software differences.  I was on custom back then, but currently on Revo (stock mode).  I think the best reason for doing it is the exhaust note.  The extra bass around 1500rpm reminds me of MK2 GTIs from back in the day, and they sounded great on the factory exhaust!
ljc19630
What ARBs are you using Kev? Also, I've been chatting to Damian at DPM and looking to get the Powerflex Handling kit. Are there any other bushes worth changing other then what they advise?
Louie
pudding
Quote from: ljc19630 on August 23, 2019, 11:49:01 AM
Louie
Hi mate, my full chassis spec is as follows:
Eibach ARBs (26, 23). Rear ARB on stiffest setting, front on softest.
Ohlins Road & Track coilovers - 50% damping front, 25% damping rear.
SuperPro 90 Shure console bushes.
TyrolSport Deadset.
TT front top mounts (stiffer rubber than GTI).
MK7 front calipers with Clubsport S 2 piece discs.
Rear completely stock.
Stock geometry.
That little lot is amazing.  It's hard to believe a humble Golf can drive so well!  I've been in far more exotic cars (most BMW M cars) and in all honesty, the little Golf chews on their bumpers easily on challenging roads.
I don't recommend poly bushes anywhere except the consoles, but take your pick from Powerflex, Whiteline or Superpro, they are all the same.  By all means refresh the other bushes with new OEM rubber, but don't fit poly.  Keep the chassis as predictable as possible and remember super sticky cornering in the dry doesn't always translate to predictable behaviour in crap weather.  VW did all that tuning work for us with their chosen bushes and geometry  :happy2:
JTI
DSG Service, Brake Fluid Change, and Cam Follower replacement done (but car still running rough af  :signLOL: )
terrier
Slack day at work so millers oil and mann filter change.  Not very often you get paid to change your own oil  :happy2:
Next year Ill change it on a weekend £££
RobC
Fitted a Mk7 Golf rear badge/boot handle...
bobby_fodge
Quote from: RobC on August 30, 2019, 09:21:38 PM
How much faff was encountered fitting the badge?
RobC
Quote from: bobby_fodge on August 30, 2019, 10:09:28 PM
Very little mate. Mounting holes are the same as the Mk5 so just removed the tailgate cover, undid the wiper motor nuts and pulled it through to give me access to one of the badge screws and then undid the badge and replaced it.
Even the electrical connector is the same so just plugs on, however it is on the other side compared to the Mk5 so I had to loosen/move some of the retaining clips in order for it to reach.
Makes a massive difference though imo and saved me the hassle of painting my old one!
MIJ_JAGGER
Quote from: RobC on August 31, 2019, 08:45:37 AM
Looks good and clean
Do you have the part number for the mk7 boot handle please?
RobC
Quote from: MIJ_JAGGER on August 31, 2019, 12:06:44 PM
I dont Im afraid but it looks like any Mk7 will fit. I think the one I have may be from an Estate as it has a drain connection that comes straight out whereas the Hatchback comes out at 90°.
MIJ_JAGGER
Quote from: RobC on August 31, 2019, 01:22:15 PM
Ta very much mate [emoji1360]
kodirl
Quote from: ROH ECHT on May 18, 2019, 06:41:22 AM
Quote from: ljc19630 on May 11, 2019, 05:40:55 AM
Should be standard equipment on the floor of every home's garage!!!!!
What is that and where can I get one?
Sent from my Mi A2 using Tapatalk
