What did you and your MKV do today?
Started by ROH ECHT, June 12, 2011, 03:07:21 AM
Previous topic - Next topic
kharma45
OllieL
Quote from: Matimcfet on October 04, 2019, 08:08:29 PM
Quote from: Pudding on October 04, 2019, 07:51:11 PM
Quote from: Matimcfet on October 04, 2019, 07:44:33 PM
Anyone got any idea what the spark plugs are gapped too when you have a stage 1 (apr) map?
They don't need gapping, just bung em' in.
Well I tried this but the power is cut at like 5.5k... almost like its hitting limiter early :(
Crank position sensor?
Matimcfet
Not even going to pretend I know anything about that [emoji23]
OllieL
Quote from: Matimcfet on October 14, 2019, 10:17:45 PM
Did you solve your problem in the end?
Think I had this problem briefly when my car was sat during the winter.
Ollie
Matimcfet
Hi mate, no hasnt really fixed! Seems intermittent though ??
neilw
#11675
I went to R-Tech, for Walnut blasting, Injector cleaning, and remapping.
The cars now 321hp and 347ft/lbs. Stock it was making 250hp with the exhaust
Edition30 #0002 R-Tech Stage2
bobby_fodge
Quote from: neilw on October 15, 2019, 09:15:56 AM
How long did that all take?
neilw
Quote from: bobby_fodge on October 15, 2019, 09:52:08 AM
Dropped it off at 8 am, I was only way home by 3
bobby_fodge
Another oil and filter change. Also did a dsg service using vcds to check the temp of the oil so the level was correct. That dsg oil stinks.
GVK
 @bobby_fodge  About 10 yr ago I worked at a VW main dealer, the first time I did a DSG oil change, I'd seen the other guys use an air line blower into the special tool to 'help' the oil go in a bit faster.
I used too much pressure in the blower and split the plastic bottle. DSG oil went everywhere.
You're right it does stink.  :sick:
bobby_fodge
I used a tool off ebay, tubing with metal connectors on either end, one went onto the bottle of oil, the other screwing into the drain/fill hole in the gearbox.
When I finished filling it still I managed to cover my hands, arms and floor in oil.
Fluid coming out was darker then that i put in. It's been 20k miles and 18 months since the last change and the gearchange is noticeably smoother now. VW say the service interval is 40k miles, hmm.
RobC
Quote from: bobby_fodge on October 16, 2019, 10:43:58 AM
Mine has just tipped over 40k so is due. Be interesting to see if it does smooth it out!
pudding
Strong numbers  :happy2:
Mine made exactly 230ps (what's that, 227hp?) on my shop's dyno, as VW quoted, but let's not go there  :grin:
GVK
#11684
Mine did 239hp on my local Maha dyno stock with cat-back Milltek, Maha's are usually quite conservative.
When it was stock it showed about 181 g/s on the MAF which is roughly 226hp as above.
After remap it was 310hp but shows around 243 g/s which is about 303 hp - it's there or there abouts for a stage 1.
