What did you and your MKV do today?
Started by ROH ECHT, June 12, 2011, 03:07:21 AM
Previous topic - Next topic
mjmallia
#12825
As part of my final 100k service on the GTI having changed the cam chain, adjuster and tensioner last week...... I changed the primary and secondary Lambda sensors as they tend to slow with age if not come close to end of life.
Got BOSCH items from Opie Oils as they are the same as genuine ones (also made by BOSCH) but a lot cheaper at £110 for both.
She should be good now for another 100k......touch wood  :wink:
Mike
South Coast
mjmallia
On a positive note, I have noticed that my exhaust tips have become a lot less black/sooty (90% less) since the lambda replacements, so the car must be running a lot more efficiently now  :happy2:
Mike
South Coast
lazy
Quote from: mjmallia on November 08, 2024, 12:48:05 PM
Have you noticed better fuel consumption or is it too soon to tell. I was surprised how quick mine get sooty and I'd like to see an increase MPG.
mjmallia
#12828
Yes the exhaust tips are def a lot cleaner after a week, as mine too used to get very sooted up.
Fuel economy has def increased, but unsure how much exactly in the last coupe of weeks.
What I have noticed is that I usually have about a 1/4 of a tank of fuel at the end of a week consistently (stick £30 in and it bumps it to about 3/4 full, but last weekend noticed I had a lot more left doing the same journeys at just under half a tank left, so just stuck less in.
I will monitor it closer, but wish I did it sooner now  :grin:
Mike
South Coast
lazy
It's not something I would have thought about doing but it's definitely going to be on my to do list now.
ZoliWorks
Same here. In fact it's gonna be te next thing I do along with the low pressure pump, n80 valve and evap canister.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
ZoliWorks
#12831
Decided to allocate some funds to the car again this month and did a suspension refresh. New Lemförder sway bar end links, new Bilstein B4 sport front and rear shocks, Eibach Pro-Kit coils from my old Jetta (7k km on them tops) and new dust/mud guards for the shocks along with new Lemförder strut mounts front and rear.
Car feels a lot more stable and wheel hop went away for the most part. It's slightly stiffer than my factory sports suspension but overall seems more comfortable for some reason. It's stiffer when going over speedbumps for example but a lot more comfortable when driving on a slightly uneven road. Next up I'll probably get a 034 Motorsport solid rear sway bar for the suspension as the car still understeers. Drove a friend's Audi A4 B7 and oversteer feels better than understeer.
Also changed to winter tires since it snowed the other day.
Before
After
I can definitely see why Eibach isn't selling black coils for the GTI. This thing is actually slightly taller in the front than stock (could just be cause of the new shocks not having more than 300km on them so far) and the rear doesnt have that much height difference. The stiffness difference compared to stock wouldn't be worth it for a lot of people. Red coils would serve their purpose better.
Edit: Used photoshop to line up the wheel on the before-after photos. Front is the same height as before the suspension update, rear is lower.
ZoliWorks
#12832
Winter update just dropped, everything is slippery. Went to get some BurgerKing and on my way home tried to keep up with a BMW (I think). Safe to say FWD, no LSD and -5c on slippery roads dont mix too well. I'm on Vredestein winter tires but I start slipping even when just lightly coming off of a stop light.
stealthwolf
After sixteen years and 150k miles, it was time to say goodbye. It went in for part exchange for an M340i. It's been a blast having the ED30. It's been awesome to be part of this community. Thank you to everyone past and present.
Mekaniko
Quote from: mjmallia on November 01, 2024, 03:52:54 PM
Now this is also on my list. It was a plug and play or the connectors needs to be redone?
Mekaniko
Quote from: skkane on July 11, 2024, 07:58:53 PM
Installed the carplay / android auto capable usb/aux box with the wiring.
This is not a Discover Merdia right?
ZoliWorks
Changed my manual transmission oil the other day. The old oil was 19 years old and had 150k on it. When it came out, you could literally tell which part was oil and which part was water. A few of the mechanics I consulted with said it's likely due to condensation cause of how hot these engines get. I was in a rush so didn't take any pictures but I've attached a picture that i found on google that looks almost like mine.
After searching through the forums, I've decided to use OEM G052171A2 which my local parts dealer had a hard time sourcing. He said he called up almost all his suppliers until he was able to source me 3 bottles as this part number has been discontinued since 2020 and the new stuff is twice as expensive. 3 bottles of this and a bottle of Febi that I used to run the box at idle for a minute to flush it, set me back about 125 euros. The gearbox took about 2.6 liters of oil to fill up.
Result? slightly smoother gear changes when hot, virtually no sticking or hanging when cold. Before the oil change when the engine was cold and the car was rolling, sometimes I couldn't even put it in 2nd and it would always stick when coming out of 2nd. That all went away now.
skkane
2007 ED30
richievr
a few days ago this happened to my mileage .......
skkane
Dropped car off at body shop at the start of Feb to replace rusty side sills / bonnet / fenders and fix misc other rust spots they found. Full respray coming. Should be all done next week. Getting wheels refurbed after so she'll be looking fresh.
2007 ED30
