Emptied my Catch Can Today……..
Started by vRS Carl, October 18, 2009, 02:03:56 PM
Previous topic - Next topic
vRS Carl
Well i can safely say the catch can works  :grin:
After around 1k miles this is what had been collected in mine  :surprised: :surprised:
As you can see from the pic that is nearly 120ml of Carp which would have gone back into the head.
Now all i have to do is show the missus how to empty it whilst im away  :grin: :grin: :grin:
Carl :happy2:
stealthwolf
What do you do with the stuff afterwards? Presumably can't pour it down the sink.
vRS Carl
Quote from: stealthwolf on October 18, 2009, 03:45:27 PM
Can't you :surprised: :surprised: :grin:
You could drink it  :laugh:
I emptied away in a friendly to the environment way  :wink:
Carl :happy2:
Hurdy
Small 1ltr oil container. drain the dregs into it and then when it is full take it up to your local tip where they have oil and hazardous waste disposal :happy2:
Phil Mcavity
or pour it back into the engine were it came from  :laugh:
:popcornsoda:
Deako
#1493
joesgti
emptyed mine after 100 miles, there was about a mil of water.  :signLOL:
Deako
Reason i went for the Stage 1 fix on mine. Fit and forget. Catch cans are unnecessary. Its only excessive pressure throwing the oil out, its not bad oil. The catch can only looks like the stuff that was in it is minging because of the mix with water.
#1493
JPC
ergh...nasty stuff
Quote from: Deako on October 19, 2009, 02:48:04 PM
forgive my ignorance, but whats the stage one fix?
gillm
i drained mine after 1k and had about the same amount .
west tuned gt28 @ 340hp
RedRobin
KRL
#12
^^^ Hey Robin.
In answer to your question - the stage one version does not filter and catch any oil vapors like the catch can does.  It is simply a stronger version of the OEM PCV which can be prone to failure.
Deako
#13
Quote from: KRL on October 19, 2009, 08:25:58 PM
^^^ Hey Robin.
Thats not at all true. In fact, its 100% incorrect.
It completely blocks off the PCV outlet, retaining just the return line to the sump. And comes with a block off cap for the inlet manifold on the PCV inlet.
The Eurojet fix does what you describe (with an uprated check valve), but the BSH fix is much better removing the PCV from the equation completely.
#1493
gillm
but surly you still get vapour back to the sump ?
