Bruce' black one: airbase & AutoX pics
Started by the bruce, December 29, 2010, 01:21:53 AM
Previous topic - Next topic
the bruce
#45
:driver: The only race I run with the 19" Monzas.     :wink:
"You get what you pay for."
the bruce
the bruce
the bruce
Verity
the bruce
the bruce
#52
For everyone interested in anti roll bars I made this table to compare the several stock and aftermarket bars.
Be careful when comparing tube and solid types !!
In general:  aftermarket sway bars are stiffer and they are adjustable front and rear to balance the car.   :happy2:
They all reduce body roll. Ride comfort is reduced just by a small amount.
Some examples:
model / diameter front ( x thickness) / diameter rear (x thickness)
OEM:
A3 Ambition/S-Line: 22,5 x 3,5 / 20,7 x 2,8 both tube
Golf V GTI: 23,6 x 3,5 / 21,7 x 3,0 both tube
Golf V R32: 22,0 solid / 21,7 x 3,0 tube (4-motion)
Golf VI GTI: 23,6 x 3,5 / 21,7 x 3,0 PR-0BF or 21,7 x 3,6 PR-0BM (DCC?) both tube
Golf VI R: 22,0 solid / 21,7 x 3,6 tube (4-motion)
Scirocco R: 23,6 x 3,5 / 21,7 x 3,6 both tube
Touran 170 HP: 23,0 solid / 21,7 x 3,0 tube
Passat R36: 23,6 solid / 21,7 x 3,6 tube (4-motion)
Sharan 2011: 24.0 mm / 20.0 mm both solid
adjustable sport after-market ARBs:
Whiteline: 22 / 22 mm  both solid  (non adjustable)
H&R 'regular': 26 / 22 mm both solid
Eibach AntiRoll: 26 / 23 mm both solid
KW clubsport: 26 / 23 mm both solid
H&R 'big boy': 28 / 24 mm  both solid
H&R 'big boy' II: 28 / 28 mm  both solid  (available at AWE only)
H&R 4-motion: 25 / 25 mm both solid
Whiteline: 24 / 24 mm  both solid
Neuspeed: 25 / 25 mm  both solid
Autotech: 25 / 25 mm  tube
APR/Hotchkis: 27 / 27 mm tube
(does anybody know thicknesses?)
KW CS are identical to Eibach, just painted yellow instead of dark red.
:wink:
the bruce
stealthwolf
An awesome car and some awesome pics.
What happened on the track/airfield with the cone? Oversteer spin?
the bruce
Yes, it was cold and a bit wet, so no chance to the get the rear tyres warm.
So we had overstering probs. Had a friend driving my car when I took the picture.
One hour later I had similar problems.  :evilgrin:
the bruce
WALK, front bushes of S3 arm, S3 hub and bushes of rear trailing arm.
All bushes come from Whiteline.
:wink:
Hedge
Bruce - on your pictures above can you confirm what you have their please.
Are you running S3 hub and arm with everything else OEM Golf e.g. wheel bearing. :smiley:
the bruce
Yes, the GTI wheel bearings were still good, so I stayed with them.
As I said on the S3 hub thread all the bearings have the same dimensions.
