What did you and your MKV do today?
Started by ROH ECHT, June 12, 2011, 03:07:21 AM
Previous topic - Next topic
golfmck1980
Finally getting round to sticking a new head unit in the car cant stick that rcd 300 anymore
Edition 30 num 859
Kai96
Cam follower and DV done (How bad is it ?) . My DV was defo shot to bits as the car feels 10x smoother now and a lot more responsive which is a plus.
spwd
That doesn't look too bad at all, do you know if it was ever done before and how many miles?
pudding
#10068
Annual crud clearing from behind the arch liner.  We know how MK5s love to rust, so prevention is better than the cure  :smiley:
The first time I did this after getting the car, the crud was half way up the wing, but not so bad after a year....
Back to how it should be  :smiley:  And yeah, that is a new wing under warranty.  VW don't paint the underside of it at the factory, tight barstewardss!
6waysforward
Quote from: Pudding on January 28, 2017, 06:39:33 PM
I've never thought of doing this before. Dam, another job on the list
Tornado Red GTI DSG
Kai96
Quote from: spwd on January 28, 2017, 12:35:49 PM
No clue if its been done before & currently @ 68k
MIJ_JAGGER
Quote from: Kai96 on January 28, 2017, 12:17:33 PM
Mine looked the same, similar mileage [emoji1303]
spwd
K9
flushed old brake fluids out and new in + aired the system. Much better feeling in the clutch now.
flashp
Quote from: 6waysforward on January 28, 2017, 06:56:46 PM
Somebody else who needs to do this!  :thinking:
Gone but not forgotten :-)
4ndy
The reason mud flaps belong in the bin :happy2:
slix
I remember when I took the plastic arch liners off my mk4 and the amount of mud behind there was unreal. Was 2 full dustpan and brush worth.
I am going to do the ed30 in a week or so when I get bored. Anyone know if removing the bit of sponge behind the arch is a good idea too? I've heard this aids in a lot of the rusty arches cases.
Stage "1.5" ED30 [330BHP] Rtech
pudding
Yeah you just need to cut back the foam block an inch or so where it touches the arch's folded lip.  Don't need to remove the whole thing if you don't want to.
Yeah only do it if you're bored.  I did it whilst the car was on stands doing other stuff  :smiley:
My MK4 had shed loads back there too.  It must be the rubbish that falls down the scuttle drain holes?  I can't see how else that stuff can get behind there?  It was the soggy 'mud' that surprised me.  Not sure how that gets in there, but it stays wet for ages, which promotes rust.
P3T3R
Not happy, just pulled out of the sh*tty works car park and the pressure sensor beeps at me, so stopped and a quick check revealed a screw in the sidewall of my rear tyre (eagle F1) that still had about 5mm left. So straight to the nearest tyre place that wasn't kiwi fit.
