What did you and your MKV do today?
Started by ROH ECHT, June 12, 2011, 03:07:21 AM
Previous topic - Next topic
Tfsi_Mike
Oil filter is 36mm socket on mine. Housing is plastic so might crack if using a filter strap?
scottm72
Quote from: Mertyvw on February 20, 2013, 04:09:02 PM
Got.
Air Filter , Fuel Filter, Pollen Cabin Filter. Oil Filter. 5w30 Castrol Edge Oil. Bosch Spark Glow Plugs, Oil Drainer. Oil Filter Wrench and not last but least the Boot pop modding parts :)
still cant get my boot pop to open properly unless facing uphill  :sad1:
Tortaruga
Quote from: scottm72 on February 20, 2013, 04:23:36 PM
LOL.
Sounds like a sh*te mod alright.
'07 Red manual
Kalpsn2000
Quote from: scottm72 on February 20, 2013, 03:13:04 PM
Quote from: homesqueeze on February 19, 2013, 06:19:50 PM
Quote from: scottm72 on February 18, 2013, 11:33:42 PM
if i am reading this right it looks like i have missed a mod,
are you saying you can code through vcds so that once you close the car doors and for example the windows are open you can lock the car with the normal one press of the key fob - but with this mod the windows will self close ?
can this be coded to all cars ?
cheers
You can open and close the windows remotely as standard by just holding either the lock or unlock button down. The coding is only necessary if you want just a one press action.
didnt even know i could raise the windows holding onto the key fob lol, works a treat, will code the one touch once i get vcds.
Noticed a glitch today, went into the newsagent for a few minutes and my window was open, came out and it was closed but it started to rain so obviouslly the self closing window function i got coded with vcds works - great - but - then noticed the intermittent wipers would not function apart from the first initial wipe ????
I tried it \ few times but didnt make a difference, the normal wiper function is ok but it seems to have affected the intermittent function regardless of speed set.
Will keep an eye on it as maybe it will sort itself as only happened today, if it does not fix itself that vcds option of the windows self closing when it is raining will be getting taken off,,,, anyone had this prob before ?
Do you mean auto wipe as the GTI doesn't have an (old skool) intermittent wipe option?
scottm72
Quote from: Kalpsn2000 on February 20, 2013, 04:40:45 PM
cheers
Sorry - yes i mean auto wipe,,, just drove again and still not working,,, def the window going up on its own done something to it,,, weird
Tortaruga
Have you tried greasing your balls?
'07 Red manual
Kalpsn2000
scottm72
Quote from: Tortaruga on February 20, 2013, 04:57:46 PM
yes my balls are very greasy  :signLOL:
torque777
Fitted mtec bulbs ...
sent using my own fingers
DFish
Had yet another expensive day at AKS with Alex. EGR Delete, studs now fitted instead of bolts on the wheels and plenty of abuse in both directions.
Noticed a dodgy pink and grey Leon that really does need a good hard driving session, think some magpie owns it  :P. Then parked next to it was another local Leon from my neck of the woods.
Fish
Tfsi_Mike
Quote from: DFish on February 20, 2013, 08:54:43 PM
Fish
:innocent:
andybon
Picked up the freshly painted bumper and spoiler from the bodyshop.
Tomorrow the Eibach springs get fitted  :drool:
How hard can it be?
scottm72
Quote from: torque777 on February 20, 2013, 06:28:14 PM
dude it looks like you have a light strip between your headlights and your fog lights ???
am i seeing things here as my car doesnt have that
scottm72
got wheel allingment done,
car has always been straight but it was way out  :surprised:
trying to get the mk6 steering wheel straight was a nightmare, was adjusted and test driven 3 times by a trusted mechanic,,,, got there in the end £60 so happy now lol
ROH ECHT
Replaced the fuel filter...fuel pressure, sweet pressure ;p
